Originally posted by: xTYBALTx
The reason the DFI guys are suggesting high wattage PSU's is most likely because people buy crappy PSU's rated for 450W that put out far, far less.
DFI-Street.com recommends against the 450 W Modstream, stating that 480W is minimum for any DFI NF4 board
http://www.dfi-street.com/forum/showthread.php?t=16754
That is honestly such BS... any modern computer can run on 450W, within reason. (dual 7800GTX, tons of hd's, etc)
The guy who works for DFI and one of the DFI engineers that posts on that forum says so
They're lying
it's like the 6800GT when it came out, they were saying it was required to have 450 or 480W or something, when in reality, people were running them on SFF Shuttle PC's with 240W of power without issue.
I don't care who says 480W is what you need, it's not true at all.
Originally posted by: scott
Better to buy the non-modular Powerstream instead of the mdoular one, if you believe the below (I do):
from here
Worse yet, modular plugs utilize delicate pins that can easily loosen, corrode, and burn, creating the potential for a major system failure. That's why pros specify uninterrupted wire!
Originally posted by: Topweasel
Toms stress test awhile back when they had both GTs and the dual core in them they only had one HDD and one ODD but the Intel machine was hitting almost 500 watts and the AMD was getting to the high 300's.
Really though, that just proves my (our) point. If I read you right, a 6800GT SLI rig with an X2 came out under 400W. Now, there's 400W PSUs and there's "400W" PSUs. If I was going to run a PSU rated between 420-480W for the system you just described, it would be PCP&C or maybe SeaSonic. If I wanted to go Antec or Enermax, I would look for a minimum 500W or maybe even 550W.
But the fact of the matter is that the SLI, dual core processor computer is only using ~390W.
However, all of this is really academic. Since the PSU is such an important item, and not getting enough power = "teh sux," we all overcompensate for our power needs. Which is fine, but we should understand that. So then it's a question of what is overcompensating? And how much do you want to "future proof" your PSU?
