- May 2, 2005
- 64
- 0
- 61
I am thinking about adding another 1GB PC3200 RAM to my system. So, eventually, I will have 4 sticks of 512MB of this memory:
Corsair XMS 1GB PC3200 Memory
In my current set-up, 1GB is set up to run in dual channel mode. These are the current settings (from CPU-Z):
Frequency: 220.0 MHz
FSB-DRAM: CPU/5
Cas# Latency: 2.0 clocks
RAS# to CAS# delay: 3 clocks
RAS# Precharge: 3 clocks
Cycle Time (Tras): 8 clocks
Bank Cycle Time (Trc): 12 clocks
DRAM Idle Timer: 16 clocks
My system is overclocked just a little. It is running at 220FSB x 11 (=2400Mhz) at max. Most of the time it is running at 220FSB x 5 = 1100Mhz.
My question is that will it still be running at OC'ed speed when I add another GB? or at PC3200 stock speed if I return to stock settings? I have heard that when you have 4 sticks, your memory runs at PC2700 speed. Is that the case with San Diego 3700+ as well?
Appreciate all your help in advance. Thanks.
FSB-DRAM: CPU/5
