Originally posted by: ChampionAtTufshop
Originally posted by: paco83
For a mobo runnin at a fsb of 333 (166x2) and DDR400 (200x2) does the mobo automatically apply the proper memory ratio (5/4 i suppose) or does it keep the ram runnin at 166x2? Assuming the mobo supports ddr400 of course.
on some mobos you dont have a choice of a divider, but you do have a choice to run the ram asynchronously from the cpu freq
for example on the p4pe by asus
it doesnt outright say a divider, but there is an option to select the ram speed
i guess its just easier for ppl that way
in either case, the divider is being used....just sometimes it doesnt show up as the divider persae
first up fsb until it wont post
then you will probalby have to clear the bios...read up on how to do that exactly in the manual, it should tell you how
but yeah you will ahve to at some point
or you can do what i do, up it to begin with lol
i set it to 1.85 right off the bat and upped the freq from there on my uncles 1800+ pally
the ram voltage needs increasing after you have run out of vcore (meaning you cant incrase it any more without any mods) and your frequency wont go any higher
generally it helps as it allows the ram to be run at higher speeds
Hmmmm that basically tells me everything I need to know =] THANKS!!! but when i increase ram voltage how much do i increase it by? and how do i know i can't increase my vcore anymore bios won't let me? and can you PLEASE!!!!!! do part 2? =] that website is great
Ah cool thanks ChampionAtTufshop can I pm you if I have more questions when I start o/c'in once my SLK-800 comes in? And would you happen to have any experience with the Epox 8RDA+ or FIC AU-11?
Feel free to drop me a line, I've overclocked 3 different systems so far using the 8RDA+.
Cool Thanks for offering heh I guess I'll start asking now. After I install all the hardware and boot it up what should I do? Flash the motherboard? Format my HD and install Windows??
Oh thanks and normal o/c would but to increase the multiplier, but since I'm going to be increasing the FSB lets say I get it to 166, I would get 1909htz, that is not a normal speed for a athlon chip.... What would my motherboard show as my procoessor Does it even matter? Like my friend's 1700+ is showing up as 2400+ when he increased the multipliers and fsb.
Heh cool but I have a 1800+ palomino unlocked =/
If its Tbred B, you should be able to get it there no problem.
