BonzaiDuck
- Jun 30, 2004
- 16,857
- 2,177
- 126
If you say the solder pins show "the burnies," then that's probably what happened.
The other thing: the risk that the monitored voltage understated the real voltage, when you had it up there at 1.5V-something.
I've read some customer-review posts and forum posts, though, about this "CPU-INIT" message and failure to post. I'm wondering how it happened.
Failure to post -- a blank screen -- can result from any number of things. It happened to me with a bad BIOS flash, and I replaced the BIOS chip -- no problem. Then it happened because a memory module went south.
Be sure and test your other parts, if you can, before trashing the motherboard.
You could try a Gigabyte motherboard. I'm not really totally soured on ASUS yet: a lot of people here are using later-model ASUS boards with P35 and newer chipsets. But I see that Gigabyte has a growing and mature reputation now.
Waiting for the county court to evict my tenant in Virginia right now, and missing the rent proceeds, I'd be tempted to offer you my "not even used" spare Striker and Crucials for a fair price, but I think I'll just go forward with my plan to build a VISTA-64 system out of it, and leave this one "as is."
You've been through enough misery with this, you're both inclined -- and probably better off -- trying something different. And maybe a board with a newer Intel chipset.
