Originally posted by: allies
Originally posted by: Madellga
SI-120 here. At 2.5 GHz and 1.41V, I have 32C iddle 38C load.
I tried the Typhoon, the 9500 and the SI-120. I kept the SI-120 because:
1) Easy to install
2) Good performance
3) Silent (using adjustable fan).
The Typhoon is not:
1) Easy to install (horrible is the best I can say)
The 9500 has not:
2) Good performance WHILE silent (like the Typhoon or SI-120).
And if the fans breaks down, you have to dispose it. No easy replacement.
From all of the reviews I've read the three perform almost identically... I don't know how you oriented your heatsinks and all the details, but I'd like to see some specific numbers.
I didn't write down the numbers, I was not benchmarking for a review. Using an Opteron Dual Core at 2.5 GHz and 1.41V, I have 32C iddle 38C load. That's very good.
I can tell you that:
Typhoon=SI-120 and both are better than the 9500.
I tried them on a Antec P160 and a DFI NF4 SLI-DR mobo (not the expert). The 9500 was pointing to the back of the case, toward the 120mm exaust fan.
As for the Typhoon and SI-120, orientation doesn't matter.
I recommend the SI-120 to all. No issues.
