OC 3000+ 64 need help
Indred
Hey all well I have my system up and working fine stable at 2613mhz. I'm able to boot and ran memtest for about 10-15 minutes with no errors but it won't load windows (BOSD when i load profile) when i boot 2700mhz. with my divider i know its not the ram and I was wandering if there is a way to tell if it is my board or cpu that might be holding me back. CPU is at 1.45v Venice DH-E3 stepping. I think its just wierd that it will post and run memtest but won't load windows all the way. Ideas??? Thanks
Edit: I uped the voltages to and was able to boot in to windows. How hi would be "safe" for Stock HSF on voltages.
CPU 1.50v
ram 2.8v
Its at 3X sorry i forgot to mention that. CPU Multi is 9. Like I said before i upded the voltages and i was able to boot but when i started to run prime 95 it just locked up froze and i coulndt even CTL-Alt-Del to reboot. I did memtest all night and it came up with noe errors.
update: I've currently got it OC'ed to 2784MHz Not very stable I can run windows and stuff but if I run Prime95 or some thing else it will lock up and auto reboot. I guess i could try to up the voltages some more on the vcore but i dont' want to fry the cpu idle is like 28c and i don't think load will get above 47c (locks up remember) Ideas?
