So I pre-ordered the NZXT G10 Kraken bracket back in beginning of December. After weeks of waiting I finally got it delivered last week as part of the 2nd batch, so I am very happy that I am finally able to get this bracket installed. Now for the GTX 780 Lightning. Overall I have been very pleased with the Lighting minus the crap Elpida memory. Ascetically is looks a little riced out in my opinion, with all of the blue LED lights on the back of the PCB and the color changing logo from green to blue to pink.... I mean't red.. The performance was pretty good from the stock cooler. I do however use the aftermarket Skyn3t bios on my card and run my card at 1320Mhz on the core and 1656Mhz on the memory when gaming. In order for me to get decent temps (below 80c) I have to keep the fan speed at 75% or more. At that fan speed the card is just a little to loud for my liking. This is the main reason why I decided to purchase the NZXT G10 bracket.
Installing the bracket was fairly easy, but the screws that are used to mount the All-in-one cooler were too short, so I didn't use the rubber spacers for the back retention bracket.
These little guys
Evidently NZXT is aware of the issue and will be shipping longer screws in the their 4th batch of pre-orders. People using reference cards shouldn't have too many issues, but there have been a few people with reference R9 290's that had issues with the screws being too short. I think mine were too short because I wanted to keep the back plate installed on my card. Looks too naked without it.
As you can see the back G10 retention plate doesn't touch the Lightning backplate, but it's very close. Also note, I had to remove the reactor on the back of the Lighting in order to install the G10. I don't plan on going LN2, so there really isn't a need for it. Here is what it looks like installed.
Now my Corsair 500R is not meant to house multiple 240mm radiators. So I modded, which is a cool way of saying "Cut" a section of my 5.25" bays in order to mount the Thermaltake Water 2.0 Extreme in the front of my case. Turns out that this all-in-one and most other Asetek made all-in-one's only have 12" coolant hoses.... Doh... I was about an inch and half off overall... The exception is the NZXT X40 and X60, they have 14" hoses so mounting the radiator in front of your mid or full tower case is a much easier task.. Go figure. I had no choice but to mount the radiator in the bottom of my case. The left 120mm fan is pulling cool air from the outside of the case, and the right 120mm fan is pulling some of the cool air provided by the lower front case fan. This setup is not optimal, and i'm sure I can shave off a couple degrees with a better configuration....
Test setup
The temperatures were taken using Unigine Heaven 4.0 with max settings at 1440p. I ran the benchmark for 20 minutes for each result. I then allowed 20 minutes for cool down as well. Room ambient temperature was 21c.
Here are results. They are broken down by cooling method, core and memory clock speeds, core voltage, fan speed or profile, core, vrm, memory and PCB temperatures. The GTX 780 Lightning is one of the only GTX 780's that allows for software monitoring for everything besides the core temperatures.
Now enough rambling. Off to the results!!
Now I can enjoy the quietness of gaming at 1320/1650 with the Thermaltake water 2.0 set to quiet mode using the included software. The extreme fan setting, which is basically the radiator fans maxed out to 100%, produce about the same noise as the Lighting cooler @ 75-80% fan speed if anyone was interested.
Youtube video of setup
I was able to get it up to 1502Mhz in a Valley run @ 1.42v - Not to shabby
