Originally posted by: BD2003
Originally posted by: BenSkywalker
No, he's having issues with the nForce; I am too. The DAC is just that, a digital to analog converter, it's responsible for poor frequency response, popping, etc; the nForce itself is solely responsible for the screwed up 3D sounds it creates.
When you move a sound signal from digital to analog it has to be combined from the discreet channels utilized by the sound chip to a meshed analog signal. If the DAC is not properly converting the digital stream to analog it will hose positional effects. Hook it up to an external DD receiver and see if you still have the same problems.
For what its worth though, Ive hooked it up to a dolby digital receiver in the past, and it worked great. Sound quality was only slightly lessened (as to be expected with compression), and there was little noticible delay, and no slowdown whatsoever. That being said, the only advantage is provides is the use of one cable over 3, and thats not worth it for the reduction in sound quality as far as Im concerned.
One cable over three? I'm not following that. You don't have a six speaker setup(apologies if you have mentioned that and I missed it)? I have seen issues with the 3D sound on Mafia, but that was fixed with a patch. The only other boards I've compared it to are an Audigy, PSE, SC and Vortex2 and it was better then any of those when it was hooked up to an external receiver, although with either headphones or a three speaker setup I still think the Vortex2 with A3D 2.0 had the best positional sound. Haven't had any worth while hands on time with an Audigy2, not sure how much better it is.
I dont understand why you are having trouble following the simple logic. I have used the nforce on several different speaker sets, including the z560s, the BA7800s, Videologic Digitheater 5.1s and a full Dolby Digital surround setup with a sherwood receiver, and paradigm speakers, along with a sony sub.
Since the paradigm setup was clearly the most powerful, Ill try and use that to illustrate what Im saying. Ive hooked it up three ways, using all 6 speakers connected analog with 3 y cables, using only the dolby digital output on the spdif, and raw PCM on the spdif. The raw PCM only came out stereo of course. The raw PCM had the cleanest sound, being purely digital. The 6 analog sounded great as well, but of course not as good as the PCM because of the DAC. The dolby digital sounded the worst, due to compression. But when it comes down to it, the difference between them was entirely negligible when compared to the distortion and crap that the nforce 3d algorithms added in.
Positioning was just fine. I could tell perfectly where the sounds where coming from, that is not at all the issue. The issue is the screwed up eax, the crackling, the muffling, and the bugs in just about every game Ive tried.
The most recent example I can use to illustrate this is the call of duty demo. When I first started playing it, of course I turned on 3d sound. I played it, and while it was perfect surround, I couldnt imagine why the sound effects were so terrible. I would have figured it was just the game had I not turned the positional audio off and just went with the standard sound, and the sound effects werent muffled anymore. Threw my audigy in, and 3d audio sounded great, as good as the 2d, but positional.
Ive said it before, and Ill say it again. I know what the dac does, I know how it works, it is the nforces audio drivers and 3d algorithms that are total crap. I'm not saying this cause Im a bitter audigy user or anything, Im still using my nforce but I refuse to use the 3d audio on it because its so bad. Try it for yourself in call to duty, and pay specific attention to the sound of your own gun, and youll see what Im saying.
And yes, the 3d sound is great on the xbox, because its a console. Im sure the nforce can produce perfect 3d audio when its the only sound card that needed to be programmed for, but its all out of wack in the pc realm.
