-1000 MHz relative to half of effective frequency: for example, from the GeForce GTX 1060 and 1070, from 4000 to 3000 MHz.
On Windows, I've used NVIDIA Inspector (best in that it can set the lowest memory frequency), MSI Afterburner, and EVGA Precision XOC (previous two can only go to -500 MHz). Is there something else I can try? I want to be able to set memory frequency to idle (405 MHz) to save power for the core overclock, because the application I currently run has almost zero need of memory bandwidth.
