- Jun 5, 2003
- 1,465
- 0
- 0
I Already have both these cards so Cost is not an issue. What card do you think i should keep ...the 1 i get rid of is going into a comp at work, That will never be used for playing games but will use some AutoDesk Viz ( 3Dmax ) and CAD programs.
But i don?t care about work and what card goes into that system is irrelevant just want to make sure I?m left with the best choice for gaming and yes i plan to play games now and in the future. so your advice is ???
