Originally posted by: OCguy
Originally posted by: Shaq
It's possible that AMD was ahead of Nvidia and decided to redo the design to make it more competitive based on what GT300 is going to be. I'm sure AMD knows more about what Nvidia is doing than we do.
It takes much longer than a few week delay to "re-design" a chip based off of what your competitor may or may not be doing.
>1yr...basically you don't.
If you find out competitive info regarding the chips that are going to debut (dubbed N+1 chips) then typically you factor that info into the currently ongoing initial stages of your chip N+2 development.
The design pipeline is so lengthy, and in a lot of ways serial that stopping at stage 5 (in project roadmap) to redo something at stage 2 phase based on competitive info then requires redoing stages 3, 4, and 5 all over again.
It's prohibitive. Sometimes small tweaks can be done to attempt to intersect a newly developed market careabout, but it is truly grueling on the development team and resource intensive. The respin of Barcelona for B3 stepping to eliminate TLB bug really sapped a lot of resources from other planned projects for example.
Unless they're going for a respin where they can get higher clocks, right?
Minimum 2 months from the start of a respin iteration until silicon is out of the fab and into your testers to verify the respin worked. Absolutely minimum of 2 months, that's full-speed crisis mode, drop everything else, all hands on deck, world will end if we don't get this done at absolute breakneck speeds. 8 weeks, and you hope your rushing about didn't introduce new bugs that escaped detection because you gave your verification team so little time to do their job.
