Nemesis 1
Originally posted by: apoppin
Nvidia licensed LongRun2 from Transmeta (power management), not core CPU architecture licenses/code morphing.
Not so, SunnyD
http://news.cnet.com/nanotech/?keyword=Transmeta
http://www.deviceguru.com/transmeta-seeks-buyer/
In August of this year, video-chip powerhouse Nvidia paid Transmeta $25 million for a ?non-exclusive license to Transmeta?s Long Run and LongRun2 technologies and other intellectual property? for incorporation into future Nvidia chips.
and worth reading:
http://www.computerworlduk.com...ndex.cfm?articleid=225
Nvidia has this nowAccording to the complaint, Intel and Transmeta were working together until a dustup over the value of Transmeta?s IP (intellectual property). Transmeta says that Intel folded up its chequebook but kept using Transmeta IP in Intel designs. Having just declared itself the new papa of the green x86, it looks bad that Intel might have let a little of Transmeta?s 1-watt 32-bit x86 leak into Intel?s performance-per-watt chips.
.... In 1995, Transmeta set out to create a metaprocessor, a CPU that could assume the personality of another. Transmeta first created Crusoe, a uniquely flexible CPU with a native VLIW (very long instruction word) architecture. Itanium is another VLIW design, but as opposed to Intel, Transmeta never required developers to code to its CPUs? native architectures. Instead, Transmeta wrote Code Morphing software to translate x86 instructions into native VLIW operations on the fly. Any 32-bit x86 software you choose runs, unmodified, on a Transmeta CPU. Translated code is cached, so Transmeta processors -- the current being Efficeon -- speed up as they learn the instruction mix of your applications.
The Code Morphing software not only translates x86 code to VLIW in real time; it analyses the code it?s translating and makes fine-grained adjustments to CPU voltage and clock frequency based on performance demands and thermal conditions. It?s key that Efficeon doesn?t rely on the OS to measure load and change speed and voltage. Efficeon and Code Morphing measure and adjust to demand by themselves. Transmeta calls this LongRun, and LongRun2 pushes power-saving technology further by greatly reducing the amount of current that transistors leak while they?re in the ?off? state.
Now do you see why intel is panicking and suing Nvidia .. and Nvidia says, "screw you" we can do better than you can with our own CPU; - 1-3 years time frame 😛
- it is a huge slap in intel's face and designed to throw them completely off balance
- imo .. of course, it is would i would do if i was gambling
I really don't see the point here. Intels has full access to all of transmeta patents. AL of them .
http://www.macworld.com/articl...2007/10/transmeta.html
