News NVIDIA and Intel to Develop AI Infrastructure and Personal Computing Products
Josh128
1,529
2,280
I think building a set of products around Nvidia GPUs that compete with it could cause considerable harm to Intel. If Nvidia prioritizes their own set of products, for example, it will be hard for Intel to compete when customers simply can't get their hands on the latest GPGPUs unless sold as part of an Nvidia rack.
It could also work fine. But risk remains. If the situation for Nvidia demands it why wouldn't they throw them under the bus.
Intel is currently dead in the GPGPU / datacenter GPU space. Therefore in that regard I really think they have
marees
2,237
2,874
This seems to be Intel trying to stop the bleeding vs AMD in DC by adding nvlink integration
Basically Intel is the new mediatek (with some additional packaging capabilities)
gdansk
4,749
8,054
I'm not talking about Intel GPGPUs. If Intel builds Xeons for NVLink but if it turns out Xeon customers cannot get anything to NVLink together then it's a lost investment.
If Nvidia did this because they felt pressured they may feel no compunction when the pressure dies of fat. And then do what they rather preferred all along.
adroc_thurston
8,485
11,203
If Intel builds Xeons for NVLink but if it turns out Xepn customers cannot get anything to NVLink together then it's a lost investment.
You do understand that those will be kustom Xeons with kustom IODs?
Like you're misreading what's happening because nvidia is EVILLLLLLLLLLLLL and so on. boring.
Josh128
1,529
2,280
eh good enough.
MI500 comp here we gooo.
low.
high.
Even if they manage to catch up with TSMC, they have to be able to do it at similar cost. That is going to be the real challenge.
For CPUs, they wont have a problem other than the above.
Thats the conundrum, if 2 is dependent on 1, and 1 is also quite dependent on 2, that makes it doubly hard and is basically why they are in the situation they are in, currently.
Josh128
1,529
2,280
That's the easy part. Perf/power/yields are Very Hard.
Disagree completely on that being the easy part. The two go hand in hand. Taiwan labor costs and working environment expectations are not the same as those in the United States. The circa 2017 days of selling monolithic 8 or 10 core prosumer CPUs for $2000 ($4000 in todays dollars) are long gone.
gdansk
4,749
8,054
You're misreading it because muh Tegra sucks. Nvidia isn't stopping anything.
Intel benefits if they can develop better custom chips on time and competitive with what Nvidia is doing. If they miss, tough luck. No reason for it to exist if they mess it up again.
adroc_thurston
8,485
11,203
Engineering=labor.
Again, wafer costs are driven not in per-headcount opex, but general node costs and foundry capex intensity.
That's why Intel is e-begging for 14A customers. 14A will be a very capex-intensive node and they need to recoup the investment somehow.
Reactions: marees
Joe NYC
4,200
5,779
I fully expect Nvidia to start investing heavily into Intel's labs and start making some of their products there in the 2030s. This is a win for Nvidia, they need to be diverse in their manufacturing
Why do you think NVidia would be OK on inferior process node competing against AMD on superior node?
It will happen with Rubin vs. Mi400, and NVidia wants to correct it in generation after that, and wants to jump to A16
marees
2,237
2,874
It will happen with Rubin vs. Mi400, and NVidia wants to correct in generation after that, and wants to jump to A16
In the history of GPUs, anything made outside TSMC fabs has suffered an efficiency penalty
That has not & will not change. Nvidia will make all its chiplets at TSMC. Maybe Intel can compete with CoWoS
MS_AT
934
1,854
This is more relevant in context of server Tegra.
Actually I was thinking along the lines of consumer market, where nVidia could only sell NVLink enalbed parts. Mediatek would cover WoA, Intel normal Windows. Since gamers buy nVidia because its nVidia it could sell. Still probably in practice they may not want to do that as every sell counts.
Btw do you suppose that Vera will be their last custom ARM affair? Or Intel plot is only to increase TAM for their "super chips"?
