Originally posted by: alchemize
Originally posted by: Moonbeam
More nuclear waste that will never be properly stored as the master poisoners continue to lie and contaminate the world.
When are you sleepy eyed fools going to wake up to the fact that if we were ever going to safely dispose of nuclear waste we would have already done so.
The only truly "safe" disposal would be launching it into the sun. Quite an expensive prospect.
Perhaps you should open our sleepy eyes to a viable alternative to nuclear energy that creates less waste and produces as much energy cheaply and efficiently? Or would you just have us all die, leaving mother earth to recover nicely.
Not really. Ideally, yes. Problem: rockets do still explode. And, the payload for a big rocket is quite small. The better way might be with space elevators to hoist the waste to low Earth orbit, and from there it could be more easily hurled into the sun. But they're a long way off, too.
Reprocessing would help reduce the amount of waste present, and would serve to extend existing uranium supplies.
Finally, send more money to fusion research. Start projects. More test reactors. Something! Fusion would, at
worst, produce low level waste that would be dangerous for up to 300 years. There's also no danger of a meltdown, as there would be no chain reaction. Right now, fusion reactors use magnetic fields to confine a plasma stream, in which the fusion reaction occurs. If the magnetic field fails, the plasma will expand, cooling it. It will then hit the walls of the chamber, cooling it further. Either one would serve to stop the fusion reaction.
Alas, a commercially viable fusion reactor is decades away. China and India are growing faster than that. Oil supplies will get tight. Our options until we reach the fusion era are: more coal (more mining, more pollution), more nuclear (waste storage issues, and we need reprocessing facilities), and renewables (expensive, inconsistent output).
