NU-Tech 082 Burning DVD's but not CD's???
taquim
72
Yah what a pain this drive is for me. Got it because of the great review from AT. First one I got didn't read CD's so I returned it for another. This one I have now has been working great, until right now when I tried to burn my first CD. Doesn't F*in work! Stops before it even starts burning. Burns DVD's great, backed up 80 gigs of files the past week on DVD's. Reads CD's too.
Am I doing something wrong? I doubt it, but I'm open to suggestions. Otherwise this thing is going back, and you know I'll probably try it again, but the next one I get will either work or will be dropped from a very tall building.
Yes I did update to the latest firmware.
KristopherKubicki
1,636
Hey man,
Someone emailed me a couple days ago with thesame problem. Is your drive alone on its own bus? That seemed to be the previous culprit.
Kristopher
Goi
6,770
7
Hmm, how can the drive being alone in its own IDE channel cause such a problem?
Anyway, what exactly happens when you try to burn a CD? What software are you using? If you're using Nero Burning ROM, you do know that there's a pull down menu to choose between DVD and CD burning right?
