WelshBloke
Just because polling rate isn't the culprit doesn't mean it isn't latency.
No. but I'm not seeing how this is latency if the device is responding (pretty much) immediately and following your input smoothly.
Short story is thats how Android works, if you don't like it theres plenty of other (well... at least two) OSs that work differently that you can use.
The above isnt meant to brush you off but you aren't going to be able to change that input method and theres no point in sticking with something that you find unacceptable when there are other alternatives.
