Just thought I'd quote my original diagnosis from your original description.Originally posted by: Pacfanweb
Uh, oh. That doesn't sound like the pilot or throw-out bearing. They don't know when you're in gear or not. A release bearing you can tell is bad just sitting idling in neutral. Pilot bearings (or bushing, don't know about yours) SHOULD make noise regardless....the crank is always spinning, and if it's going to make noise, it should do it when in neutral, not when moving.Originally posted by: Eli
Everything seems fine though. The transmission shifts fine, the engine runs good and sounds fine when revved in neutral.. but there is a horrible noise when moving forward. It's not a wheel bearing, its only present when in gear.
<--pats self on back.
And I think I'll reiterate my thought that, Damn Eli, you are rough on cars.
Guess we can't totally blame this one on you since you just got it, though.
So what's the estimate to fix this one? Hope it's not too much.
Maybe get a used one and slap it in there. Take the top cover off and inspect it first.
