Originally posted by: Genx87
Transformers is probably one of the best examples of HD quality out there. Another movie that looks really good in HD is Blades of Glory.
Originally posted by: PurdueRy
Dark knight is fantastic...especially in the IMAX filmed scenes
Originally posted by: mshan
This guy has some tuning parameters you could try for various Vizo tvs: http://www.tweaktv.com/tweak-my-tv/vizio-2.html
Originally posted by: pontifex
I have a 42" vizio 1080p LCD HDTV and a PS3. I'm watching Transformers, which is a rated as a tier 0 reference quality blu-ray and I don't see much, if any, difference between it and the DVD version.
How far away are you from the screen?
Are you looking for differences in color as well as resolution?
How are you comparing one to the other?
About 10 feet
That's too far to get the full benefit of 1080p for a screen that size.
According to this chart which I've used too much, at 10 feet away from a 42" screen, you'll only see some of the benefit of 720p over 480p, let alone 1080p vs. 720p.
http://s3.carltonbale.com/resolution_chart.html
I don't understand
http://pics.bbzzdd.com/users/Y...inch10feetistoofar.png
X-axis represents screen size
(your 42" screen size is marked in red now)
Y-axis represents your seating distance
(your 10' viewing distance is marked in black now)
The intersection of your screen size and viewing distance indicates what resolution you'll be able to resolve with 20/20 vision.
For example, with your 42" display (red vertical line), if you were to sit 15 feet away from it, you wouldn't be able to tell any difference between 480p and anything higher if you consider resolution only.
If you were sitting 5 feet away from the same 42" display (still on the red vertical line), you'd be able to fully resolve 1080p and would even see some benefit going higher (when 1440p is available... or whatever comes out next after 1080p).
At your 10 feet viewing distance, you're in the area between the green and blue lines, meaning that you will not be able to fully resolve 720p with 20/20 vision, but you will see some benefit over what a 480p signal would give you.
When considering resolution only, you are too far away from the TV to get the full benefit of 1080p and even too far away to get the full benefit of 720p.
this shit is retarded...
Heh... which part? That chart just shows how close you have to sit to a given screen size to see the full detail of a specific resolution. So for your 42" screen you would need to sit roughly 5.5 to 6 feet away, or closer, to see the full detail of 1080p resolution.
it's retarded that you have to follow some stupid chart just to get good picture quality. i don't even understand the point of having blu-ray or hdtv resolutions if you have to sit that close or why they even make hdtvs in anytihng under 50" if it doesn't do a damn thing at all.
Oh no, people should research things before they buy them! 😉
sorry, but i don't see how sitting X feet from the TV, when it is X size, while standing on your head, reciting the Koran backwards, and farting amazing grace at the same time to get a good picture quality is research. it's a fucking tv and video player, not rocket science. it should look good at any distance.
i did enough research on actually choosing a tv that fit my budget and had the features i wanted. i shouldn't have to worry about distance and picture quality. its just retarded that it doesn't work at normal viewing distances.
they tout hdtv and blu-ray as so great, but no one tells you anything else. you shouldn't have to go to forums and learn formulas just to watch fucking tv.
Agreed .........I want to watch a movie .... Not perform a technical analysis of the photograph on the screen.
Do you play PC games on the lowest resolution with all the eye candy off, too? 😛
no, but you don't have to go through hoops to make it look good. it's just a few simple settings. and it looks good on just about any size monitor.
Now stand ten feet away from the monitor.
why would i stand 10 feet from the monitor?
Originally posted by: Spicedaddy
10ft viewing distance, you should've gotten a 50" 720p plasma. And Vizio isn't known for having the best colors/contrast...
i'm sorry i don't have 1000s of dollars to spend on a top of the line tv...
i started watching black hawk down today (BD). the picture seems better in this movie at 10' than transformers did. i moved to 6 feet andit looks grainier than at 10'. i don't have a dvd of this so i can't compare dvd vs. bd
That's good. You're starting to see the detail if it looks grainy. That movie is purposefully grainy.
Originally posted by: SithSolo1
Some people just can't tell the difference.
Take my father for example. I've got a 58" tv and every sitting potion in the room is between 7 and 9'. If I were to show him a scene from Transfomers on DVD and then immediately one from Blu-Ray, he'd say they were the same.
I on the other hand can spot a "night and day difference" as you put it. The colors pop and the image is much more crisp.
Just watched Role Models one BD and that definitely looked better than DVD quality. It was really sharp and clear. I guess it depends on the movies too.
So you see a big difference in role models but not transformers?
yep, except for the close-ups of the transformers. they look better than DVD but the rest of the movie doesn't seem better than dvd
and this was at 10' too
Originally posted by: Rio Rebel
Your eyes see more detail at closer distances, and less detail at farther distances.
So science (specifically biology) is now "bs"?
no, but 10' vs. 6'?? it's that much of a difference. thats like 2 steps for me. i we were talking like 50' vs. 10', then i might agree with you.
10' to 6' is almost halving the distance.
For reference, a 42" display at 6' is a 28.5 degree viewing angle.
At 10 feet away, that's equivalent to a 70" display.
Saying sitting at 10 feet vs. 6 feet doesn't matter is about equivalent to saying that it doesn't matter if the TV is 42" or 70" if you were to stay at 10 feet away.
That's over 2.75 times the screen size.
At this point he really doesn't want to see a difference. Once you get to that point there is no standing for reason. Kinda like those reviews of how power cables/digital interconnects really improved the "tightness" of their bass and "widened the soundstage" and sounded more "transparent"
😕 i spent all that money because I DIDN'T want to see a difference? WTF? are you insane?
I do see a slight difference, but not the major difference i was expecting. YES, EVEN AT THE RETARDEDLY ARBITRARY DISTANCE OF 6'!! which i've proved doesn't do a damn thing vs. the 10' i've been sitting at.
Originally posted by: Pacfanweb
^Most TV's are set on "blow torch" mode from the factory, so they'll jump out at you in brightly-lit stores. They usually need to have brightness and contrast turned down to see everything properly. I've seen some BR's that have a calibration place on the menu.....sort of like the THX Optimizer that's on a lot of DVD's.
To be fair though, this is sort of like complaining that no one told you that you couldn't read the book you just bought from 10 feet away. Granted, the TV is less obvious, but it's the same principle. This isn't some artificial limitation, but rather a limitation of the human eye.
i don't even know how to respond to this because it makes absolutely no sense. thats like comparing the 13" tv in the post above...i'm not trying ot look at something tiny from 10' away. I'm lookin gat something huge from 10' away.
Originally posted by: bl4ckfl4g
I just got a bluray player and it barely looks better than my upscaled
DVDs from my Pioneer. The big difference though was the sound. BD audio is amazing even just running it through my TV.
I have to agree.
This is why I eagerly anticipate a 73" in the price range I'm comfortable with 🙂
(have a 65" currently)
