Spicedaddy
10ft viewing distance, you should've gotten a 50" 720p plasma. And Vizio isn't known for having the best colors/contrast...
Originally posted by: YOyoYOhowsDAjello
The only hoop you have to jump through is sit close enough for your given screen size and resolution.
The point of the distance comment on the PC games is that setting graphics options to high only makes it look better if you're close up. (Options meaning resolution and possibly Anti-aliasing relating directly to the blu-ray issue you're talking about).
The same issues come into play here that you don't seem to be buying into.
I don't know what kind of monitor you have, but say for example it's 1280x1024.
If you set the resolution to 1280x1024 and 8xAA, it will look great when you're 1-2 feet from the monitor. 800x600 and 0xAA would look really bad.
If you stand at a greater distance away from the monitor (like the 10 feet suggested), you will notice much less of a difference between the 1280x1024 8xAA screen compared to the 800x600 screen since everything is going to look rather blurry from either monitor. You won't be able to see all the details that the 1280x1024 resolution made sharper because you just can't see things that small from farther away.
Did you try the two pictures I hosted for you to try out? I can't tell if you're honestly still confused by this or not.
yes, i looked at the pics. isn't the closer i am to the display, the worse it will be because i'll see the pixels?? i wouldn't see the pixels further away?
if i watch a tv show in ym monitor and sit up close, its not very clear. if i step back it looks clearer.
There's a balance between sitting close enough to see all the detail vs. sitting so close that artifacts and pixel structure become distractions.
With HD, the main appeal is that you're essentially getting 1920x1080 images to display and play back at native resolution. With an upconverted DVD, you basically get a 720x480 source that you then convert to 1920x1080 either by the player or by the TV.
Going back to my island view example that doesn't seem to be helping, I've zoomed in a little to make detail more specific.
Looking at the house in the middle...
1600x1200 image (zoomed in and resized to show detail)
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/House1600.jpg">https://mywebspace.wisc.edu......ndom/House1600.jpg</a>
The 640x480 image (same process used as above)
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/House640.jpg">https://mywebspace.wisc.edu......andom/House640.jpg</a>
With the higher resolution image, you get to see that the house has siding on it, that the bush in front has individual leaves, that the house roof is made up of several panels, etc.
These kind of details are what you're paying for by getting a 1080p TV and a 1080p source.
You have to sit close enough to the TV so that you can see these details.
You're right that you can't sit too close though since everything just looks like a pixelated jumple if you get too close, regardless of the starting resolution
1600x1200 too close
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/Junk1600.jpg">https://mywebspace.wisc.edu......andom/Junk1600.jpg</a>
640x480 too close
<a target=_blank class=ftalternatingbarlinklarge href="https://mywebspace.wisc.edu/spmclaughlin/web/Random/Junk640.jpg">https://mywebspace.wisc.edu......Random/Junk640.jpg</a>
Detail is made up of pixels... so you have to sit close enough so you can see changes between the pixels, but not too close so that the structure of individual pixels becomes obvious or distracting.
Nobody is suggesting that you sit 3 feet away from a 42" TV. You'll be be distracted by the pixels and you'll probably end up straining your eyes / neck from the "first row in the movie theater" effect.
Having more pixels in your HDTV allows you to sit closer without seeing pixel structure and there's more detail there since there are more pixels to work with. Right now, you're too far away to see the details that higher resolution is able to display.
those are huge differences in picture quality though. as i said, i'm not see any difference. if the difference was that pronounced, shouldn't i still see it no matter the difference?
i'm sorry i don't have 1000s of dollars to spend on a top of the line tv...
i started watching black hawk down today (BD). the picture seems better in this movie at 10' than transformers did. i moved to 6 feet andit looks grainier than at 10'. i don't have a dvd of this so i can't compare dvd vs. bd
That's good. You're starting to see the detail if it looks grainy. That movie is purposefully grainy.
Another random example (with side-by-side pix): EnchantedOriginally posted by: YOyoYOhowsDAjello
Go find some comparison pictures of Blu-ray (or HD-DVD) vs. SD-DVD.
Originally posted by: s44
Those of us who have adjusted to sitting at HD-quality distances laugh at the "DVD looks just as good" argument. It's nonsense.
sorry, but i don't see how sitting X feet from the TV, when it is X size, while standing on your head, reciting the Koran backwards, and farting amazing grace at the same time to get a good picture quality is research. it's a fucking tv and video player, not rocket science. it should look good at any distance.
i did enough research on actually choosing a tv that fit my budget and had the features i wanted. i shouldn't have to worry about distance and picture quality. its just retarded that it doesn't work at normal viewing distances.
they tout hdtv and blu-ray as so great, but no one tells you anything else. you shouldn't have to go to forums and learn formulas just to watch fucking tv.
compared shoot em up DVD. vs BD and i do see some difference, sharper image (less jaggies), but i was expecting a night and day difference between BD and DVD but it's only a slight difference.
And once again...you're sitting too far away from a 42" average/below-average tv to see much difference.
If you cant tell the difference 6' away, either your eyes are bad or you did not set everything up correctly. End of story.Originally posted by: pontifex
this was at the 6' that is "required". so don't give me that bs again.
Just watched Role Models one BD and that definitely looked better than DVD quality. It was really sharp and clear. I guess it depends on the movies too.
