not enuf power??
Furl
ok so i want to get a vid card that requires a 350watt psu would it hurt it to run it on a 300 watt psu??
You should be fine then.
If your system is unstable, you can always get another power supply, however Antec makes good power supplies, so I highly doubt there will be a problem.
Originally posted by: Furl
im gettin that 6800gt asus edition... v9999 or some thing like that
According to the power supply calculator, your system would use a max of 300 watts if every component was running at 100% load (this would never happen BTW).
What is the model number of your power supply?
You should be fine. It wouldn't cause damage, it just would be unstable during gaming if it wasn't getting enough power.
I would personally give it a try. Antec True series are very good units.
350 is minimum requirements, but you might want to consider a +400w PSU depending on how much power you're really using, not just based on your GFX card.
