Ahurtt, I agree amps shouldn't be a problem for you.
To test your locks, drop the HTT multi to 3x, Drop you CPU multi, and set ram to DDR266, and see how high you can push the HTT. You should be able to get HTT to 300 or above, then check your bus speeds in Clockgen. If they are still 100 & 33.34 you know the locks are working. (If your locks aren't working you most likely can't get over 220 or so)
To find your best overclock use a memory divider to take ram out of the mix. And increase HTT slowly a few steps at a time, and when you start getting errors in Prime95 then up the vcore until it gets stable and continue increasing.
To find you best RAM overclock, drop your CPU multi taking the CPU out of the mix. Set ram to DDR400, and use the same method slowing increase the HTT, but now use memtest to test for stability and when you start getting errors relax the timings and or up the DDR volts.
Using this isolation method will allow you to find your best CPU overclock and your best Ram overclock, you can then start working on your best combined overclock. The problem with just increasing the HTT and overclocking CPU and RAM at the same time, is that when you hit the wall you don't know whats stopping you.
If you do the three steps I've outlined and test your maximum HTT, CPU, and RAM, this will give you a clear picture of where your limitations are, and allow you to squeeze the most out of your particular setup
