seattledesi
my rig:
939 3000+
asus sli bios 1003 final
mushkin value ram 2x512mb 2.5-3-3-8
xfx 6600gt
antec 350W psu (21a at 12v)
board is rock stable at stock! Peak load temp 37C.
After reading that 1T is better than 2T, ive set the dram config in the bios to :
ddr400, 1T, cas 2.5
At HTT multi 5x, and HTT 200, and cpu multi 9x (thats the max for this chip), prime95 looks stable.
At HTT multi 4x, HTT 220, and cpu multi 9x, xp boots but prime95 fails..
So I change dram settins to all auto, keep the above settings..
cpu-x says memory is still running at 220hz..
prime 95 still fails...
questions:
1) when all settings in dram is auto, is it using 2T? Any tool that will help me confirm?
2) is it really worth oc'ing this cpu using 2T and memory dividers.. will I get better benches?
3) i'm not able to change HTT settings using AI booster.. is it because AMD cool and quiet is running?
thanks for helping..
939 3000+
xfx 6600gt
ddr400, 1T, cas 2.5
questions:
