- Jul 11, 2001
- 40,903
- 10,228
- 136
I now think there's probably nothing wrong with the battery charger described and linked in the OP. I also am thinking that the onset of the problem with the introduction of the charger was just an odd and very unfortunate coincidence. I'd decided to try to work up some charts or graphs to help me to determine the correspondence of charge on the batteries with voltages across the terminals and time needed in the charger to get to target charge levels. To do that I used a digital multimeter to get voltages across the batteries' clips. In so doing I undoubtedly widened those clips to the extent where they made at best so-so contact with the phone's battery studs, ergo the problem.
The last post (mine, #25) with its link to Battery University's li-ion technical page has in depth info. The skinny from my point of view in a nutshell is that most chargers charge to 4.20 volts and call that a full charge. If you charge to only 4.10 volts you will get a 90% charge but get twice as many charges before battery failure. The Battery University page says this:
That tradeoff of 10% of capacity for double the longevity is one I'd like to make. However, commercially available chargers don't give you that option according to the Battery University page. I wish there were an app that would let me do that! It might not be technically possible given the nature of the hardware, I don't know. My workaround generally has been to take something off a complete charge ASAP, thus my hesitation to put my phone on a charger before I go to bed. However, I may start doing that. Prices of li-ion batteries seems to have dropped a great deal in recent years!
Most Li-ions are charged to 4.20V/cell and every reduction of 0.10V/cell is said to double cycle life. For example, a lithium-ion cell charged to 4.20V/cell typically delivers 300–500 cycles. If charged to only 4.10V/cell, the life can be prolonged to 600–1,000 cycles (which they say is ~90%); 4.00V/cell should deliver 1,200–2,000 and 3.90V/cell 2,400–4,000 cycles. Table 4 summarizes these results. The values are estimate and depend on the type of li-ion-ion battery.
 Facebook
Facebook Twitter
Twitter
