- Jul 11, 2001
- 40,903
- 10,228
- 136
This phone which I received middle February has IIRC always worked fine. Got it off Amazon. I bought a replacement battery off Amazon which appeared to be exactly like the original (1430mah), but seemed to hold a better charge. Tired of always having to tether the phone when charging either battery I looked around for a battery charger and bought one that's presumably (it says) specific to this battery, a BL-5J. Got it off ebay, but it appears to be exactly the same as one you can get at Amazon.
BL-5J battery charger I bought at ebay
which looks to be the same as this:
BL-5J battery charger sold at Amazon
Today, I put my replacement battery in the charger (the phone said it was 57% charged before I did this), and it seemed to be charging fine and the indicator light finally changed from pink to blue signifying a full charge. I shut off the phone, and swapped batteries but the phone wouldn't power on with this, the replacement battery which had just been topped off by the external charger. I swapped batteries again and the phone would still not turn on! Finally it turned on.
Now things are quirky. It turned on a couple of times with the replacement battery (the one I charged in the external charger) but instead of powering on as usual it just showed a low battery indicator. Most of the time it doesn't even do that when I press the power button. With the original battery in the phone, it did turn on once or twice, but most of the time it either won't respond to the power button or else it seems to try to turn on and then turns off. Oddly, it will start the power on process, go dead and then start it again, go dead, start again (this cycle takes about 18 seconds, first time was way shorter, about 5 seconds...all this without my touching it), etc. etc.! At the moment this is what happens when I plug the charging cable from my laptop into the phone. That normally just turns on the phone and begins the charging process. Unplugged, the phone is not responding to the power button. This is using the original battery.
This is nuts and I don't know what to think. Is the phone acting crazy (borked or something), are the batteries to blame (one of the batteries was never put in the charger)? If I can get the phone to start again the first thing I'm going to do is go to the apps list and write down all my apps. I will never be able to remember all of them if I have to get a replacement phone.
The phone has an Airvoice microSIM in it and a 32GB microSD card.
Could be coincidences going on here but logic tells me that the charger fucked up the replacement battery and that that battery then fucked up the phone! What do you make of this?
 Facebook
Facebook Twitter
Twitter
