Node 202 Case fans.
What's the rest of the build? Are you adding the case fans to an otherwise completed build, or are you still planning your build?
http://www.anandtech.com/show/10342/the-fractal-design-node-202-case-review/3
AT said:
The card can only be up to 310 mm long and up to 50 mm thick, if no intake fans have been installed beneath the card (or if 10 mm low profile fans were installed). If 120 mm × 25 mm intake fans are installed, the thickness of the card is limited to 35 mm.
So, you can fit two 120 mm fans under the graphics card, provided the graphics card is not too thick. A standard dual slot card is about 40 mm thick and already prevents the installation of regular 120 x 25 mm fans, but you will be able to use 120 x 12 mm and 120 x 15 mm fans, of which there are a few models: Prolimatech Vortex and Scythe Slip Stream Slim, for instance.
I'm still planning my build, thank you for answering my question.
