Noctua NH-D14 - will it fit?
pleniluneorg
I have the Corsair 650d case. Does anyone have the same setup? I don't have SLI if that matters.
Thanks
stahlhart
Super Moderator Graphics Cards
Dec 21, 2010
4,273
77
Welcome to the forums.
the Noctua's tower is 158mm tall -- if you've already got your motherboard and CPU, measure from the CPU surface to a best guestimate of where the inside surface of the case's side panel will be.
That was how I did it, anyway. I ended up only having a margin of error of a couple of mm, but the Silver Arrow fit inside the 690.
