Originally posted by: herbiehancock
Did anyone catch the 26 120mm fan review done over at XtremeSystems?
Interesting read.....seems that the Noctua, while very quiet at low rpm's, also has a very low cfm output at the same rpm's. The short quote about the Noctua was: "Quiet only buys so much when the blade design is grossly inefficient.:
The Yate Loon SL turned in an impressive performance for low speed, very quiet fans as did the Silverstone FN121.
The Papst 4421FGML and the Sharkoon Golfball 2000 were the better choices in the medium speed, low-to-mid noise fans.
Go here to read the review.....pretty good read.
He did not test the S-Flex line nor a few other popular choices of fans. He does plan testing others, like the S-Flex, at a later date and the results from that testing should be easily comparable to the currently tested crop.
