No temp monitoring on X800 XL
grimlykindo
546
I just got my ATI Radeon X800 XL ($299!) PCI-E and I installed ATITOOL for the purpose of monitoring my temps (no overclocking yet). It doesn't show the temp and when I look at the log file it says: "Temperature monitoring not supported by this card." I'm using the 5.3 catalyst drivers and got a score of 5200 on 3dmark05. So It seems that my card is running fine. Shouldn't this awesome card show me some temps?!?! My crappy 6600gt had the temp support build into the drivers!
mwmorph
8,877
there arent any.
only xt cards have temp montioring, or cores with a xt card in the lineup. this particular core on th .11 micron die only has the plain x800 and the x800xl so no temp monitor is built in.
Keysplayr
21,219
54
Yeah. My X800XTPE has temp monitoring. Sorry dude, looks like your only solution is "dermatemp". (Place finger on heatsink). :)
SilkySmooth
123
I have a BBA Radeon X800 XL and it has temp. monitoring via ATITool. You need to use ATITool 0.24 beta 2 or higher. Latest beta version is 0.24 beta 5. You can find it here.
grimlykindo
546
Hey, I only have the .23 version, I will have to try the .24 2+ beta. I won't hold my breath though;)
grimlykindo
546
Originally posted by: RacerX
Try RivaTuner ... it monitors temp perfectly with an ATI X800 XL
Really? I thought rivatuner was mostly for Nvidia? I used it on my 6600gt, but I guess I never thought about using it on my X800 XL
By the way, do you guys like you x800 xl? I love mine! I makes my 6600gt look like it was from the stone age!
