A couple of days back I got a motherboard based on Intel 810 GMCH0set & ICH (82810 + 82801) chipset which supports all Socket 370 and Slot1 processors. It has integrated (onboard) audio and vga port.
On it I run Intel Celeron 667 with 64MB RAM.
I installed Win98 SE but there is no sound from the system. I installed the necessary audio drivers for Win 98 SE (WDM) from the motherboard drivers CD. Even then there is no sound. I installed the display drivers and the display is working just fine.
According to the motherboard manual the audio chipset is from Analog Devices, Model : AD1881. But on the chip on the motherboard its written AD1881A.
In System Properties under Device Manager there are two hardware devices under Other Devices : PCI Card and Unknown Device. Both have a circled exclamation points on their icons. On clicking the properties it says that the drivers for this device are not installed(Code 28). When I try to reinstall the driver, it cannot find the driver even in the motherboard drivers CD. What are these two devices?
I don't understand what the problem is. I have enabled the AC97 Audio and AC97 Modem in the BIOS under Integrated Peripherals.
Please help. Thanks in advance.
Srikanth
Srikanth
