I recently built a computer with the following parts:
CPU: Core i5-4690k
Motherboard: Gigabyte GA-Z97X-UD3H ATX
RAM: Corsair 16gb 2x8 DDR3 1600
SSD: Samsung 120 GB 850 EVO SSD (OS boots from here)
HDD: WD 1 TB Caviar Black HDD
GPU: GTX 960 SC 2GB
Power Supply: Supernova 750G2 80G PSU
Optical Drive: LG 24x DVD burner
OS: Win 7 Pro 64bit
CPU Cooling: Corsair H55 Liquid cooling kit
Case: NZXT Phantom 410
Display: Acer G276HL Gbmid 27-inch (1920 x 1080)
I spent a weekend getting it setup. I'm not a newbie, but not an expert either - somewhere in between. While building it, I had no issues at all with "no signal" to the monitor, but I was using a totally different display while setting it up which makes me suspicious of the monitor I'm using now.
The Problem:
When I start it up fresh in the morning, it usually takes between 1 to 3 reboots before the monitor will finally get a signal and display the mobo load screen. Either that or I just press the reset button and it sends a signal to the monitor. This didn't happen while I was building it and constantly restarting for windows updates. But I was using a different monitor while I was building it and it was plugged in with DVI not HDMI.
What I've Done:
-24-pin and 8-pin power plugged in
-GPU power plugged in
-all case fans plugged in (2 exhaust, 1 intake)
-all hardware is seated properly and all necessary cables are plugged in, including all front panel cables
-proper number of standoffs on motherboard
-I/O shielding installed
-CPU cooler firmly in place with thermal paste
-All drivers are up to date (358.91 for the GPU) for motherboard, gpu, and all peripherals
-Ran all the windows updates
-ran CCleaner and virus scans.
Everything else is running smoothly and there are no other issues with the computer except for this problem. I even followed this guide on setting up my SSD: http://www.overclock.net/t/1156654/seans-windows-7-install-optimization-guide-for-ssds-hdds
Help would be greatly appreciated. Anybody run across this before?
CPU: Core i5-4690k
GPU: GTX 960 SC 2GB
OS: Win 7 Pro 64bit
The Problem:
What I've Done:
