No problem, just curious...
Rhi
135
I was wondering why a client PC will not lease an IP through a wireless AP that is directly connected to a cable modem? There is only one client, and the AP is essentially just a hub, right? So why won't the client PC lease an IP from the modem instead of being forced to use an additional router?
-Rhi
Nothinman
30,672
If the AP is really 'just a hub' it can't loan out IPs, you need a DHCP server for that. If it's got a DHCP server built in you have a problem somewhere.
Rhi
135
No, it has no router funcionality at all. However as a simple hub I should still ba able to lease one IP through it from the modem, no?
-Rhi
Tallgeese
5,775
Make and model of AP might shed some light.
Can the AP operate in a "pure" bridge mode? If not, then that's the reason.
BTW: I am able to serve internal DHCP info just fine through an Orinoco wireless AP, operating in bridge mode.
Rhi
135
AHHhhhhhhhhhh. I didn't have it in bridged mode. Hmm.
Technically, why would it matter? I was getting network activity through AP to Cable modem, but PC wouldn't lease a valid IP. Like the network activity was unrecognized or something. I bought a router and have had no problems since, I was just wondering about the technical reasons this "wirelss hub" didn't act like a wired hub. I was unaware I needed to put it in "bridged mode". :(
Linksys WAP11
Thanks!
-Rhi
Tallgeese
5,775
Because most APs aren't technically hubs. They can either behave like routers (most default configurations) or bridges.
Routers won't pass (DHCP) broadcasts, bridges will.
Rhi
135
Hmmm. Well the WAP11 has not router funcionality at all, yet it seems to not pass DHCP broadcasts unless set to bridged mode. Annoying. Thank you.
-Rhi
