Engineer
I've looked at the manual. Some of the things you could try are as follows (you'll have to install your old card, make changes to the BIOS, save them, and try the new card again).
AGP Voltage
Use this to select among [Auto], [Normal] and [High] for AGP Voltage. The
default value is [Auto]. -----> Set to High
AGP Mode
The default value of this feature is set to [Auto]. If you install an 8X-AGP
card on this motherboard, you may select [Auto], [8X] or [4X] as the AGP
mode. If the installed AGP card is a 4X-AGP card, then you may set the AGP
mode as [Auto], [4X], [2X], or [1X]. -----> might try setting manually to 4X or 2X to see if it makes a difference.
AGP Fast Write
This allows you to enable or disable the feature of AGP fast write protocol
support. Toggle it on or off (enable or disable) to see it's effect if any.
The next three things I really don't know what they will do but I would try different combinations of the Aperture Size to see if that matters (I think not). You could also set the AGP Staggered Delay to 1ns to see if that effect the card as well as changing the AGP GADSTB Output Delay to various combinations to see the effect. It will take time to do all of this but it's worth a try.
AGP Aperture Size
It refers to a section of the PCI memory address range used for graphics
memory. It is recommended to leave this field at the default value unless the
installed AGP card?s specifications requires other sizes.
AGP Straggered Delay
Use this option to select AGP straggered delay. Configuration options:
[Auto], [None], [Delay 1ns]. The default value is [Auto].
Use this option to select AGP GASSTB output delay. Configuration options:
[Auto], [None], [Delay 150 psec], [Delay 300 psec], and [Delay 450 psec].
AGP Voltage
AGP Mode
AGP Fast Write
AGP Aperture Size
