Question no connection with static IP for my NAS
ws1960
hello i have a NAS that i built with supermicro x8st3-f with xeon 5570. it is running windows server 2019. and running very well with PLEX media . but last week connection is lost with the yellow caution warning. i do have a static ip set in bios and ivp4 in windows . i also have check cables and i also tried the auto con fig for non static without any connection as well. i am try to get some good pics for my NAS on here . i have raid 6 and raid 1 with about 20TB plus os in SSD and two samsung SSDs . the case is a Antec P101 very very nice . the cooler is a nochta all very quiet. 1100USD. it cost me. hope the new years good for everyone .
so what happens when you log on to the server? does it show it has its ip working and can connect to internet? or is it waiting for a reboot since it installed updates?
so i can login to server , and the ipv4 is now working with autoconfig connected. but it will not connect or save ipv4 settings i input. so it is conected and it did update wnds. the static ip had been working for a month or two prier thanks .
are you talking about the server's ip or your computer? server should be on static ip.
the one with the problem is a server with windows server 2019. i do have a pc and it has dynamic ip.
Did you create another account that's not in administrators group after setting up the server, and use that account trying to set a static IP?
If that's the case, that's probably why the static IP won't stick. And what do you mean yellow caution warning?
Is it on the network adapter in device manager? That means the NIC malfunctioned.
i have to NICs on here and the yellow warning is were it would be a red x for no cable connection. i will look under device mngr see if there are errors there. i am logined in as admin i a m only user . thanks
