PlasmaBomb
Originally posted by: SagaLore
I'm looking for a molecule that is mostly comprised of nitrogen atoms, and is liquid at room temperature.
Ideas?
Nitric acid?
or NI3 and KNO3 are solid at room temp.
HNO3 isn't mostly nitrogen and the salts are both solids. Although 70% conc nitric acid is fun...
im aware they are both solids...
A lot of liquid chemicals are a mix of hydrogen and/or carbon. I just want to find one that is nitrogen. It needs to be liquid at normal pressure too - or a solid that is readily soluble.
They are both solids that aren't mainly nitrogen was the implied point. Sorry if it didn't come across that way.
I like the idea though, as at least they are reasonably safe...
NI3 is not safe, not even close.
Depends on your definition of reasonable... you can make it in small quantities and not kill yourself... unless you let it dry out.
Edit: although technically I'm talking about NI3:NH4
