15min chargers will kill your battery so fast. If you use your charger requently just pick up a nice charger and that way your batteries will have a good life and retain power easier.
I use the Lacrosse BC-900 and it is a very nice charger. (Right now it probably is a bit too pricy).
ive got the duracell, it works good, just cause it charges at a high amperage doesnt mean it will kill it, i use mine for the radio for my RC car and it works like a charm
The 15 minute chargers use specially constructed cells with built in overtemperature interrupts. They typically function as 1 hour chargers on cells not so equipped. Those are basically a waste.
