Originally posted by: BullsOnParade
Finally, i desperately need something larger than this 256mb cf card, can anyone confirm whether the 2.2gb cf cards are worth getting on ebay ?
according to a fellow user, it works in the D70. i ordered one and will see if it works when both the camera and cards arrive. i'll also try it in my other camera (canon powershot s500) to see if it's compatible elsewhere and report back with my findings.
okay, we got it working. naturally, as it's a CF type II card, it won't work in cameras that accept CF type I only (like my s500 -- i wasn't aware of that at the time).
according to some findings i read on the nikon d70, the camera does accept microdrives but you should pay extra care to these devices as they are what you buy: micro harddrives. that said, if you dropped a harddrive, chances are you broke it. likewise, you need to handle these items carefully or they'll break. but if you just leave the microdrive in your camera, it should be fine -- because i'm not sure if you're planning on dropping the camera anytime soon.
for the price, it's a good deal. i'd go for it if you want big storage for a low cost, but bear in mind that there's a lot of care that needs to be taken if you plan to buy it.
one more thing: nikon recommends that you do not use a microdrive when upgrading firmware on the cameras (e.g. D70 to D70s, which i did). i had a spare 512MB CF card that i used instead, and it went well.
i'm glad that the d70 accepts both CF type I and CF type II cards.
