sze5003
Because the n6 is not uncomfortably large to hold or use, carry like a tablet. I use my n6 with one hand without issues.If one likes big phones, why not just add a phone app to a tablet?
how is the reception on the n6. I heard motorola phones are best in terms of signal quality. When are they rolling out wifi calling on the n6? I keep hearing it's going to out and tested but I haven't seen it yet.
I have advanced calling on Verizon in 5.1 but I dunno about WiFi calling. I use hangouts for that. The 5.1 update helped fix the low call quality issue in 5.01.
I dunno what it was but many people were complaining about the speaker for the phone, while on a call, could barely be heard with the volume all the way up.low call quality issue?
it was probaby EVRC-B being turned off...?
My N6 should be here within 4-5 hours... Planning on customizing it thru XDA forums, but it looks complicated.....
Everything on XDA looks complicated. Hell, even the forums themselves look complicated.
Nexus root toolkit is all you need. Google it and download.Just arrived, took it out of box...
Yeah, feeling a bit 'dazed and confused' (as I'm reading XDA posts about ADB and Fastboot)... charging brand new N6 now, later will put the Ting sim in and go to their site... tomm.
Avoid toolkits.
Just learn to do it the regular way. So that when (not if) you screw something up, you can fix it.
Toolkit is super easy but you should always learn the manual way. Also never lock your boot loader on 5.1. Its not as easy as before now.
I just know I'm going to mess this up... Lord, have mercy...
If it's your first smartphone, why the rush to mess with customizing it at that level? People usually resort to custom roms and what not after using their phones for a while.
Yes it absolutely is great stock. Most people root and rom to get rid of carrier bloat, which you really don't have to worry about in this case.I was thinking the exact same thing. As a fellow Nexus 6 user, I would advise just rocking the standard rom and everything for a while. I can't touch mine as its a company phone, but its a pretty rocking device just stock.
I'm not sure, everyone with a nexus 6 agrees they had low in call volume. After the update it seemed to be better.That's probably phone issue honestly. Not network related
I would at least look into unlocking the bootloader. That way in the future if you want to root and customize, you can do so without wiping all of your apps and info.....
