nexus 4 + data connectivity
dabuddha
19,579
17
Last couple of days my data connectivity has been spotty. Normally, the icon in the top right is blue colored with a H above it. What happens is it'll stay gray and the H will flash on and off every 5 seconds or so. And data doesn't work. First couple of times, I power cycled the phone and it worked again. This last time, I put it in airplane mode and then off and it fixed it. Is this a common problem? If not, is there a way I can get some diagnostic log messages about the connection?
s44
9,427
16
Check to see if the SIM is sliding out, then (if not) try testing with a replacement SIM from your carrier. Otherwise, I'd look at RMA...
dabuddha
19,579
17
Straight Talk (using an AT&T sim).
I'll check the sim card but when this is happening, I'm still able to make phone calls. Just the data dies until I either power cycle it or turn airplane mode off and on
Durvelle27
4,102
Hows the coverage in your area
dabuddha
19,579
17
It just happened again. I wonder if it's related to the wifi connection. It seems to happen when I have wifi and the data turned on and I disable wifi. Had to airplane mode cycle it to get it to reconnect
Durvelle27
4,102
Was the sim card cut
dabuddha
19,579
17
Yeah it was. This is my second nexus phone (had the first one replaced because of a camera issue after using it for 3-4 days). I didn't have a problem with the data at all on the old one. I have with this one.
superccs
999
I an having something similar to the op data behavior. On T-Mobile nexus 4 new Sim cut from T-Mobile. Data just lingers in the grey and does not connect... Then resolves itself after a time. WiFi is also kind of spotty at times.
lothar
6,674
7
Post your APN settings.
When I was on Straight Talk a while back I was getting problems. I solved the problem by leaving the "proxy" field in APN settings completely blank(despite the guide on Howard Forums stating that one should fill it out with that "http://tracphone" stuff).
dabuddha
19,579
17
Sorry for the late response. Got swamped this weekend
APN: att.mvno
Proxy: Not set
Port: Not Set
Username: Not Set
Password: Not Set
Server: Not Set
MMSC: http://mmsc.cingular.com
MMS Proxy: 66.209.11.33
MMS port: 80
MCC: 310
MNC: 410
Authentication Type: Not set
APN type: Not set
APN Protocol: IPv4/IPv6
APN roaming Protocol: IPv4
APN enable/disable: enabled
Bearer: Unspecified
Feb 19, 2001
20,155
23
the grey bars means no connection to google services. i'd be more worried about APN at this time than anything.
Not sure about you guys but the SIM tray is tight on the Nexus 4. Don't see how the SIM slides out that easily. Plus that's not really a big issue for most people I'm pretty sure.
