Originally posted by: GeezerMan
OK, so I ordered some expensve Corsair ram for 216.00, but has a 40.00 rebate. It arrives in the factory blister pack, but the edges had been cut off, so it had been opened before I got it. Is this common? I'm not thrilled to get open box items at all, especially expensive ram.
Is there a easy way to tell if I got what I paid for? I set up the Asus A8N-E mobo with the recommended settings from the Corsair forum, and I'll run the memory test they recommend on it tomorrow. Still, kinda peeved I got an open item. I might call them tomorrow.
Originally posted by: JEDIYoda
Not to bend some people out of shape.
OK, I got the lowdown from Corsair. For some reason, they don't seal the ram. My opinion is any expensive components should be sealed up. I bet the retail versions are sealed up, or the retailer locks them up. Kingston does seal their ram up, at least their value ram I had previously was sealed. Personally, when I shop locally, I don't buy open box items.
I still think this thread has value, so I don't regret posting it.
Newegg came in and posted a response willing to help, so that reflects well on them.
I'm trying the memtest again, I had the voltage at 2.60 volts instead of the suggested 2.75 volts
Well, looks like this topic has been discussed over at the Corsair forum as well.
They really got into it over there...
http://www.houseofhelp.com/v2/showthread.php?t=38942&highlight=sealed
yes--very informative!!!Originally posted by: Zebo
Sounds like vendors requested unsealed to put thier own serial on modules so guys cant try and RMA old for new or bought somewhere else for newegg. Perfectly legit request IMO with all the crap people try and pull. All that really matters is does it work at advertised speed and looks new since warranty in 100% lifetime on mem.
The factory Corsair rep also has a comment about the reselling of opened packages being done against their recommendations
Originally posted by: kevinf2090
ya i know, i don't think corsair seals their package, you just unsnap the edges and you take the ram out
[q]Originally posted by: GeezerMan
Exactly. I've got tons of Corsair RAM and none of it has been melted or glued on the edges, but it does have a lip with some friction and it does snap shut. It has always showed up closed and well-packaged from NewEgg. I actually appreciate not having to bust out the scissors or pry at the package and send the memory flying across the room when it pops open.
GeezerMan (and now Ken90630) seems to be grossly overreacting. It is totally misleading to continually say that Corsair RAM is "not sealed" when it comes securely snapped into a friction-fit package that is itself closed and does not seem to have any problems with accidentally popping open.
I can't think of any situation where the memory would need to be better sealed. If the RAM has been used, you can tell by inspecting the contacts. If the RAM were being sold in a store, it would be behind the counter.
I guess if you don't trust the vendor, you might want it to be sealed, but the bottom line is that an unscrupulous vendor is actually more likely to tamper with the package and then put some kind of seal on it afterwords. The vendors have plenty ways to seal things if they want, so simply having a sealed package doesn't mean everything is brand new.
If you're going to get so bent out of shape about memory ... then what about hard drives? Those don't come in any kind of box. How hard do you think it is to get a sealed anti-static bag?
What's really the worst that could possibly happen with memory? "Oh no! My memory with a LIFETIME WARRANTY has been used!" How much does that really matter?
