Originally posted by: bryanW1995
according to the xbit article, 70w cooler at load with the max OC. The nice thing for me is that it looks like only 36w more than an e6850 at 3.7, which is a good approximation for my e6750 at 3.6. The thermals were the biggest reason for me to hold out for the penryn quads, hopefully they won't disappoint
Doing some simple math, assuming 70W difference, that is 1.68 kw/day, so ~ 50 kw /month. assuming 10cents per kw hr that is $5 per month in savings.![]()
Originally posted by: GuitarDaddy
Neweggs early adopter pricing:I've already seen the X3350 oem in stock for $315, I wouldn't touch this one at $300 with a ten foot pole
actually it's 323.98...nudge...you're only getting 33,000ppd right now, why not shoot for 40k?![]()
Where ?
moogr.com (sister company to xcaliberpc, links to the same warehouse) use coupon code "marchmadness"
Retail box after coupon applied $324.99, OEM after coupon $314.99
Here's the link to the OEM
Where ?
it's not accepting the code for the retail box when i go to checkout... it doesn't accept the code either even if I do google checkout![]()
Originally posted by: TheJian
Originally posted by: blackangst1
What am I missing? Isnt the Q6600 for not much more a better CPU overall?
Not at all. Every single benchmark will be won by the Q9300/X3320. Period. And that's not including the fact that it runs cooler, should overclock better based on the 45nm process (assuming a board that can hit 2000+fsb) AND comes with SSE4.1.
The faster FSB, 100mhz, and core improvements make it win 7% avg in everything.
http://www.xbitlabs.com/articl...y/core2quad-q9300.html
Q9300 vs. Q6600. Q6600 didn't win ONE test.
Look at the power consumption. Q9300 is 100mhz more. Now look at the overclocked ones at Q6600 3.6ghz vs Q9300 3.5ghz. Which you would probably need to get close to the Q9300. A full 70watts!
I might want the 3350 if I bothered though. Easier overclock without huge FSB.
But your wallet usually dictates what you do...LOL
Although Yorkfield processors can overclock up to 4GHz (without any extreme cooling solutions involved), Core 2 Quad Q9300 cannot reach that frequency. Since the new quad-core generation started supporting 1333MHz bus, their multipliers got considerably lower. For example, Core 2 Quad Q9300 we have discussed today works with 7.5x multiplier, which doesn?t allow this processor to get past 3.4-3.5GHz because contemporary mainboards have pretty limited functionality when it comes to increasing the FSB frequency past 460-470MHz by quad-core CPUs. And this is actually even lower than the maximum frequency quad core processors from the Kentsfield family, including Core 2 Quad Q6600, can reach.
As a result, Core 2 Quad Q6600 may remain a better choice for overclocker systems, because it may run faster than Core 2 Quad Q9300 in some cases. Moreover, overclocking of previous-generation quad-core processors is a simpler procedure that doesn?t depend that much on the mainboard functionality.
So, it turns out pretty hard to make the final conclusion about the youngest quad-core Yorkfield processor. The new Core 2 Quad Q9300 is definitely a great product, but only until you get to overclocking. From the overclocking prospective we have to be more careful with our verdict and would call it an interesting but maybe not the most optimal choice.
Too bad you can't read your own link:
So in other words contrary to your beliefs unless you're running your CPU at stock speed actully Q9300 is the crappiest choice you can make out of all tested ones.
hehe why'd you get the retail version? You know that you can overclock much better with a tuniq, right?
do you really think that the extra 6mb cache will consume another 30w at load? that seems excessive to me. of course, I personally don't care about the extra $5/month, I just brought it up for the budget oc'er in all of us.
And I assume you know that you get a 3 yr. warranty with retail, vs. what, 90 days/1yr. max, with OEM ? And that OEM is backed by the seller, not Intel ?
Too bad you assume one result means everyone has the same result. "pretty limited" does not mean "ALWAYS LIMITED".
http://www.ocforums.com/showth...552970&highlight=q9300
Barely in the wild and already 480fsb, nothing special. One search at ocforums...LOL. Something tells me you can do better with only one result hitting 480 and only at 1.33v with no mention of anything special going on with the chipset (with an added chipset cooler for my koolance I wonder what could be reached...or any other water/chipset). It's not like he froze stuff to get there. Do your homework before you buy your board. Or better, take my advice and buy the higher multi proc. Did you miss that recommendation? I'm thinking at 3.6ghz it's pretty tough for a Q6600 to beat it unless you like room heaters or like fires.![]()
The point was is it better than Q6600 (all things considered, SSE4, power consumption, performance), not is it the best overclocker out there. Once you consider SSE4 Q6600 is dead in my mind. That has the potential to make Q6600 look like a dual core.
By this idiotic 'comment I can tell you barely know anything about SSE2 vs SSE3 or even preliminary SSE3 vs SSE4 results. tThat has the potential to make Q6600 look like a dual core.
"By the way, we performed some additional tests and found out that the performance boost in DivX 6.7 depends a lot on the type of the encoded movie. In our test fragment featuring a battle scene Yorkfield processor was only 30% faster, however, the movie suggested by Intel, with water surface ripples being the major part of it revealed almost 70% performance boost in Yorkfield?s case."
This was in Oct 2007 (xbit Qx9650 article) for crying out loud. What happens 6 months from now? Adobe just release premiere SSE4.1 update. Wonder what will happen when people benchmark that?
http://www.anandtech.com/showdoc.aspx?i=3105
Nearly double performance with only a 200mhz speed advantage on a laptop (2.8ghz Penryn vs 2.6ghz merom). What's that equate to clock for clock? 75-80% faster? SSE4 will become potent. This was a sept 2007 article. Again, evidence of 2008 shaping up to be SSE4 aware and deadly to chips base on 65nm. Any more questions? :evil: :roll:
Originally posted by: Foxery
Overclockers who invest in something as nice as a Tuniq cooler aren't concerned about warranties. If we don't burn it out in the first 90 days, it'll last until we replace it with the next hot product.
I see comments about Q6600 always getting to 3600, but then it looks like that was edited out.
Here is my take. As you can see, I don't have ANY Q6600's @ 3.6. While most can boot into windows, and some can make it for a while appearing stable, for 24/7 operation, 3500 for the G0 stepping is close to the top. My latest is stuck at 3200, but I think its the motherboard.
As for the 9300, I agree that even at 480 fsb, thats only 3600, and they are only a tad faster, but a lot more money.
I ordered a X3350 (Q9450) since I think that the 8x multiplier gives me a shot at 4 ghz with my PC-8500 memory on my DS4.
