Let me begin with a little description of myself. I would say I am way above average when it comes to computers than the average American, but I am the quintessential noob when it comes to creating my own PC. Id like a system that still has lots of room for upgrades as right now I am constrained to a budget of 1000$ but a year or so from now I should have a decent amount to spend on upgrades.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Primarily for playing/encoding/ripping movies HD movies. A HTPC system with good sound and excellent video.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$800-1000
3. What country will you be purchasing your hardware from?
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
Not a fanboy of anything
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I have a 1 tb external and a 500 gb external, and a 50 inch 1080p samsung 5series DLP tv as a monotor
6. IF YOU have searched and/or read similar threads.
Have done some research for the last couple of weeks, mainly on this website, still unsure.
7. IF YOU plan on overclocking or run the system at default speeds.
Would assume default speeds, not sure if overclocking would be good, if possible would like some help with
8. WHEN do you plan to build it?
Within the next 2 months, preferable ASAP
$800-1000
USA
