If you're working three days, you might want to consider this breakdown: chest/triceps, back/biceps, and legs/shoulders. Each day you'll have one major exercise (bench press for chest, deadlifts for back, squats for legs) and then add more exercises for the secondary parts and to put more stress on the main area.
If you're very new at weight lifting, you might consider buying a comprehensive bodybuilding book (don't know any current titles) or subscribe to Muscle & Fitness. M&F has excellent articles on nutrition and proper form and some suggested routines (which are usually worthless since they are unreasonable for normal humans, but they give you a good idea of the different exercises and how to combine them). You could also look at Flex or some other muscle mags to get more opinions and more exercises in a short span of time. If you stick with one mag, it'll take awhile to get a range of articles. Or, go to a library and check out some books. 🙂
I take creatine and have noticed some amazing results with it. I am older, however, so the effect may be more pronounced for me given the comment above. Basically, it has allowed me to work harder and longer without nearly as much soreness. I suspect that the workout intensity would probably work for you, but soreness might not be necessarily as much of an issue for you (it wasn't as bad for me when I was younger). It's a benign supplement, but do some research on your own.
Good luck!
Good luck!
