New WD Raptor Help
Muadib
18,124
912
Originally posted by: jondl
I've had experience with this board and read elsewhere that SATA 1 and 2 are unlocked on that board. So if you're overclocking, there is a chance that you overclocked your raptor and its busted. SATA 3 and 4 do work with overclocked systems. And i would also like to say that i have never had to use my SATA driver diskette to install winxp. In fact, i just reformatted last night.
Question: I'm about to go out and get 2x36gb raptors and am wondering if the DFI Ultra-D motherboards have this same problem? I currently already have 2 SATA drives installed and it would be great to know if i would be running into any problems at all.
http://www.xtremesystems.org/forums/showthread.php?t=43033 <-------------Read up on your board..
Why are you getting 2 36gb raptors?
Should i be getting a 74gb raptor? Honestly, i just saw the deal and am considering it without any research. I do remember a 74gb raptor being faster than 2x36gb in raid0. Any suggestions?
Well that depends on the deal. If it's a great price, then go for it.
I have a 74gb raptor, and if I could do it over again, I'd pass and get something bigger instead.
jondl
561
Fry's currently has it going for 89.99-30 rebate. I'm in the bay area so +tax is around $70 a drive. I currently have the diamond max 10 300gb HD running on my OS btw.
Muadib
18,124
912
That is a pretty good deal, but why 2 if you already have 300gb? You could move windows to
the Raptor, and you might notice a speed difference. Be sure and download hdtach, and run it now, and then again after you've made the switch. Be sure and post back with the results.
jondl
561
To run them in a raid0 configuration... but it seems that 1 74gb raptor will be the better choice. AHH decisions decisions.
btw did the op figure out what was up with his drive?
