New Video Card and Still LOW FPS, WTF!
If you are planning to overclock,
Get a P67 motherboard, I believe the H67 will not allow overclocking. I may be wrong here, but believe that is correct
Good luck in your upgrade!!!!
u r right i need P67,
@BFG10K
i forgot to install chipset drivers, i feel dumb a little but i was thinkin windows 7 handling it for me? i dont see any yellow or red x in device manager but i will try to install to be SURE.
and the test you mentioned is really interesting, 2120 get my attention... maybe i would save money for ivy, and get cheap 2120 for summer games
@tweakboy there is a summer holiday before ivy comes out, so i want to play in my holiday. but i will tryto buy an motherboard that can support ivy cpus
@flexcore when z68 comin?
My 6870 and i5 both at stock got 4255 but our graphic scores are the same so you are good now.
Detailed scores
3DMark Score P4255
Graphics score 4012
Physics Score 6138
GraphicsTest1 19.76 FPS
GraphicsTest2 19.79 FPS
GraphicsTest3 24.33 FPS
GraphicsTest4 11.49 FPS
PhysicsTest 19.49 FPS
CombinedTest 19.69 FPS
Detailed scores
3DMark Score P4255
Graphics score 4012
Physics Score 6138
3DMark Score P3272
Graphics score 3938
Physics Score 2261
Combined Score 2050
GraphicsTest1 19.25 FPS
GraphicsTest2 19.43 FPS
GraphicsTest3 24.45 FPS
GraphicsTest4 11.2 FPS
PhysicsTest 7.18 FPS
CombinedTest 9.54 FPS
combined and physics test shows how old CPU is 😀
thx for sharing info
in all honesty the only upgrade path i could see for you would be a 2500k with a really cheap motherboard and budget ram. There is really nothing else to even consider so enjoy the games you have now until you save some money and upgrade.
ASUS P8P67-M PRO INTEL P67(B3) SOCKET 1155 is at %25 price drop here
it will support ivy, right??
@ murcielagotr
I have played Mass Effect 2, fallout 3, fallout nv, lotro, darkspore beta, all fine with no issues. I usually have everything in high/ultra with turning down shadows and the aa to a medium level
You are correct. The P67 is overclockable but does not take advantage of the on-die GPU offered by Sandy Bridge CPU's. You therefore will need your own graphics solution either on the motherboard or (more likely) a discrete graphics card for gaming. The H67 is NOT overclockable but does let (not require that) you use the on-die GPU...which is fine for typical home office/movie use but not good enough for gaming. The Z67 is supposed to offer both abilities I believe.
CPU: intel C2D 2,93 GHZ (E7500)
RAM: 3 GB 1066 corsair DDR2
Corsair F60 SSD + 1 TB Samsung HDD
PSU: 800W bronz plus
Benq 17": 1280X1024 default res, Secondary: samsung Lcd tv@1080p res.
GPU: HD 4850(old one) upgraded to HD 6870
MOBO: MSI 7525
was my old rig
i updated a little
CPU: i3 2120 ( im going to upgrade to ivy when its out)
RAM: 2x 2 GB 1600 Gkill Ripjaws DDRD
PSU: Xliance 800W bronz plus
GPU: Sapphire HD 6870
MOBO: ASUS P8P67-M PRO
an i tested a little with stock settings now
3d mark 2011 P4016 3DMarks
http://3dmark.com/3dm11/1135454
the games i was mad about is working fine now:
TDU 2 maxed out settings at 1280x1024 its around 40 FPS avr. if i set environment to high its around 55 FPS. (i didnt update game on purpose, some mentioned pathes make it bad) This game is *uking CPU sensitive, now im happy with it
im going to test other games now 😀
i want to thank all who write here to guide me
@BFG10K the article you mentioned helped me a lot...
