New to Dual processor, need help and advice. thanks
Daovonnaex
1,952
<< I am new to dual processor platform
1) can anyone give me hardware advice like Intel or AMD and the motherboard?
2) RAM issue mainly on ECC or non-ECC
I am mainly going to use it only on games, DVD, burning, video editing
thanks
1)AMD would be superior, especially on the 760MPX chipset. Not only will you get a superior CPU, but you'll get overclocking support.
2)ECC if you plan on building a server, non-ECC if not.
I can elaborate if you would like additional help.
Daovonnaex
1,952
<< Also..How does running Durons in SMP work? Can it be done etc? >>
Just drop two Durons in a 760MP or 760MPX board and you're set. I don't know why you'd want to do that...
kelvin1704
869
thanks...
i decided to go dual...
now, the final question:
should i wait for the new MPX board or go for the tyan board?
Daovonnaex
1,952
<< So Durons will run fine if I stick them in a 760mpx chipset? >>
Yes, they will.
<< thanks...
Asus is already out with their MPX board, and it's a world-beater. The first dual-processing board with overclocking support!
Specifications can be found here
And GamePC's Review of this can be found here
Diable
753
<< thanks...
If you don't plan on overclocking the Tyan board will work fine plus its a steal at $193 at NewEgg. Just remeber to get registered memory as the Tiger MP requires it.
