New system problem
Chris A
1,431
Abit IS7
ATI Radeon 9500 pro
2 sticks of Kingston Hyper X 3500 at 512MB each.
Pent 4, 2.6C
120 gig western digital SE
Yamaha CD burner.
Ok I hooked it all up and hit the power button. Everything seems to be going fine until the monitor starts showing a image. I can read the text but it is pretty hard in some places. There are lots of little colored boxes all over the screen spaced about 1/8th inch apart.
I have tried this with two monitors one was kind of old the later was a newer Sylvania 19inch.
shootinyou
947
Did you forget to plug the power connector into your 9500?
Might try reseating the vid card also.
;edit; which power supply do you have? could be a power issue.
Take a lookhere mechbgon's
post especially.
hope this helps.
Chris A
1,431
Did the reseating Damn lever is soo close to everything... Changed power connectors... Same little colored boxes all over the screen. I can make out the words Dual channel mode enabled.. Hyperthreading enabled.. and a few other words no errors at all as far as I can tell...
Chris A
1,431
Sorry that is the only card I have.. I might have to borrow one tomorrow. I cleared the bios last time...
shootinyou
947
Some new power supplies are coming with special low voltage 4 pin connectors
for case fans only.
Chris A
1,431
Good Idea I had tried there different leads coming off the power supply this morning.
Power supply is a Enermax 330 watts.
I even tried the DVI output with the adapter with no luck.
I am thinking the Video card might be bad.
Chris A
1,431
Fan is spinning real good pulled it out and stuck in a PCI card...
PCI works fine... Loaded right into the bios on a PCI card..
I need to try a different AGP card...
Edit.
I read on ATI's Web site that there were some 9700's that were doing this same thing with certain power supplies.. I wonder if this could be the problem?
http://www.ati.com/support/infobase/4075.html
Vonkhan
8,198
my first guess wud be the power supply itself
else the power connector
or faulty fan
or maybe a bad card :p
i wouldnt say heat becuz the problem is there in 2D, and overheating wud cause it to fail or display little blank pixels randomly all over the screen
Chris A
1,431
Good Idea I am calling right now... Bet it costs me a six pack though..
If it works on another system is there any power supply that might be better?
Chris A
1,431
Tried it on my brothers system with the same garbage. Time for a new card. Thanks for your help....
mechBgon
Oct 31, 1999
30,699
Could the card be only half-way into the AGP slot? They have two layers of connectors, unlike PCI, and can be darn stiff when they're brand-new. If you can see the card's contacts peeking over the edge of the slot, it's only halfway in.
