- Oct 22, 1999
- 15,613
- 11,255
- 136
So tonight I was doing an oil change on both of my cars, using Castrol GTX 5w-30. I've been using this for at least 5 years now with no issues. I had most of a 5 quart bottle left over from my last oil change, which did most of the first car except for about 1/4 of a quart.
So I open up the new 5 quart bottle and as soon as I pulled the seal, I was hit with the very strong smell of gear lube. I decided it was probably okay and I topped off the first car, just about a 1/4 quart. Then decided something just wasn't right, so I poured some into a cup it was dark in color much more like gear lube, than the normal amber color.
I've decided to not use it on the second car and go get a different brand. My question is, do you all think I should drain the oil out of the first car and put fresh in? I couldn't find anything on Google.
