- Mar 28, 2003
- 3,825
- 46
- 91
Hey guys, not sure whether to post this in Tech Help or here, but here goes.
I am in the middle of building a new system with an ASUS GeForce GTX 970.
I've just connected all the essential power connectors, to test the machine and make sure everything spins up and gets power.
And everything seems to. Case fans spin, CPU fan spins, power/case LEDs are on. However, the two fans on the GTX will spin on start up for about 5 seconds or so, then stop.
The "LED_1" white light appears over the power connector, and nothing else.
It also outputs just fine, as my new monitor displays the BIOS/UEFI boot screen via DVI connection.
Any ideas? I assume the fans SHOULD be spinning at all times. And as a sidenote, I've tried 3 different PCI-E 6+2 pin power connectors that came with my PSU. The PSU is also brand new (850 Watt Corsair HTX).
Help.
Help.
