New GM LT1 engine
Too bad they didn't stick with that LT5...
http://www.corvetteactioncenter.com/forums/c4-corvette-zr-1/14104-demise-lt5-engine.html
The contrast between the Gen III [LS1/LS6 engine] and the LT5 engine is striking. The LT5 is both taller and wider, as a result of its double overhead-cam cylinder heads and its complex intake manifold. It became apparent that the next generation Corvette, if it were designed solely around the Gen III small block, could be significantly smaller and lighter than if it had to accommodate the LT5 engine.
Studies based on a large population of modern cars have given us the standard relationship between engine weight and total vehicle weight. Increasing an engine's weight by one pound means that the total car's weight will likely increase by two pounds. We estimated that taking 80 lbs out of the Corvette's engine would allow us to remove another 80 lbs from the chassis. In the case of the Gen III, reducing the engine's length would also contribute significant savings. Weight reduction of this magnitude is only possible when you're designing a car from scratch.
The planned future LT5 engine, with its even more complex valve train, would have been 205 lbs heavier than the aluminum Gen III. Thus a Corvette designed around the Gen III aluminum engine would weigh around 405 pounds less than the same car designed to use the LT5. As a result, the LT5 engine would have had to generate 55 hp more than the Gen III, simply to compensate for the heavier car. With the Gen III generating 405 net hp and the future LT5 estimated at 475 net hp, the effective power gain would have been a mere 15 horsepower. And, given an estimated $25,000 price premium for the LT5 engine, the cost of this small increment of power is astronomical.
The Corvette had reached a crossroads. We could design the C5 around the LT5 engine or we could design a smaller, lighter car that was fitted like a glove around the Gen III small block. By opting for the smaller package, we could achieve ZR-1 performance at the price of a standard Corvette. This was too important an opportunity to ignore. As we explored it further, we convinced ourselves and Chevrolet that this was the right strategy for the next generation Corvette. This, however left us with the conundrum that the far-superior Gen III might seem, to the consumer, to be low tech.
The Gen III uses computer management to control fuel and timing, providing smoothness, high power, and efficiency -- a very high-tech feature, but eariler forms of control -- such as the four-valve combustion chamber -- were what the public perceived as modern technology. We knew that the Gen III LS1 would do just fine without these older features, as they came at such a high price, in terms of size, weight, and complexity. Like the consumer, we had been accepting the notion that complexity was good. Yet, here was one case where just the opposite was occurring. The simple solution was almost as powerful, and it was smaller, lighter, cheaper, and more fuel-efficient. Whether it was considered high-tech or not, the Gen III was the better engine. So, in the end, the only logical choice was to back the Gen III small block as the Corvette's engine of the future -- even if it's roots dated back almost 50 years.
I'd say they chose right, do you not remember that the ZR1 also cost as much as a current Z06?
Yeah, but the S63 is a 550 hp engine, BMW will be getting LT1 numbers out of the new M3 next year with a turbo inline 6, which will be considerably lighter.
Considerably lighter? I doubt it.
I am all for this new engine and its incremental improvements. It will likely be very robust like all Chevy small blocks and I doubt that mpg number is correct.
For some reason there is a huge disconnect with some people and understanding that displacement doesn't mean engine weight. DOHC engines are *heavy*.
There is no doubt GM took the right path by sticking to a lighter motor, and I'm happy to see now that they have no increased the engine weight, I just think a lot of enthusiasts were expecting a LIGHTER motor this time
I just expected more gains out of going DI.
Not keep the same engine. Keep developing the 5.7L DOHC V8. It was already at 405hp in 1993. The Northstar came out of it, but that was basically abandoned.
Now we are going to talk about the latest and greatest 6.2L engine with only 10% or so more power 20 years later? When it seems they already had that same engine "well north of 450hp" in 2007?
Doesn't make too much sense, but maybe there's something I'm not seeing...
Or maybe the numbers are low.
After all, the 5.0 in the Mustang is making close to 450 horses without DI.
Stop looing at peak numbers, those only tell a very small part of a motor.
The biggest diff between the LT1 and the L98 in the late 80's to the early 90'e was the full power band.
Most don't run to the peak power band, most of the time its in the low to mid RPMs and newwer motors get better and better at that without giving up on the peak as well.
Lastly the numbers (milage and power) are early and probably on the low end to save face if they can't squeeze more out. Think worse case, and even then GM has under rated many of their performance cars compared to what they show on a dyno after breakin.
That's also DOHC. I can see the reasoning in saying 'you can't compare HP:L of a DOHC engine.'
I can also see the reasoning in asking why the hell GM is still making a pushrod motor, though. Yeah, yeah, it's lightweight and shit.
...the Ford is 430lbs. The Nissan V6 I mentioned is about 320, I think, without VVT (not sure how much that adds).
These aluminum V8's aren't really that special in the weight category unless you're comparing them to old iron engines of similar displacement.
Oh, and the weights I'm listing are actually complete engines...kind of sick of Corvette guys talking about their 350lb aluminum engine...uh, dude, you need to include more than just the long block and intake. I've seen complete LS1's listed as high as 500lbs or so. I'd bet an LS3 is low 400's at best.
Lighter? Show me the proof, cause right now no one really knows how much this engine weighs, or what BMW engine will weight. LS1 was 409 pounds, which is VERY light.
Yeah but German Engines cost 3-4 times the price of this one. Heck most 4 cyl German engines cost on par with new LS3. M54 from E46 was 375+lbs (add Turbo to that). VERY small difference.
I remember in the early 2000s one of the LOWEST end German 8 cylinders (W8 in the Passat) was 25-30k new. And we are talking worse performance, PITA to work on, not great reliability amongst many other things. I won't even get into the fact that they are a nightmare/expensive to modify.
Germans have a LOT to learn still cause frankly they still haven't learned anything from their WW2 engineering failures.
For now, I suggest they get the basics right.....like say, making a badge that doesn't chip and peels off within 5 years of ownership (BMW).
:biggrin:
Please don't compare an overpriced, overly complex for no apparent reason, overly PITA to work on, overly expensive to maintain and fix German engines.
Yes, the new M3 engine based on the N55 will be considerably lighter then the S63. The link compares it to the 4.4 liter Twin Turbo V8, which is either the N63 or S63 depending on if you're going for the performance variant or not.
The link states it's 40 lbs lighter then the BMW twin turbo V8, big deal. I'm saying the next M3's engine will have a similar hp/tq rating as the LT1 and it'll be considerably lighter then that tt V8 as well.
I think the numbers reported must be deliberately low.
If they were well past 450hp in 2007 with this DI "LT1", then they are surely well past that today.
I just wonder why it wasn't put in a vehicle long ago?
I agree and I think it's deliberate to not undercut Z06/ZR1 or whatever the top model Corvettes will be
That and the fact that having 500+ HP in the base model could complicate insurance issues I'm guessing
But I could easily see a more tuned version of this putting out ~550 HP, or if they apply these same upgrades to a 7L block 600+ HP. As it was the LS7 motor was underrated from the factory
I'm really picturing something like a 450 HP base model, 550-575 HP Z06 and 650-700 HP ZR1
Z06 being either a more tuned 6.2 L with a higher rev limit (this one is only at 6200 fuel cutoff?) or a 7L
ZR1 being either a 7L or smaller displacement force induction. May not need forced induction though with the GDI powerband
Personally I think it would make the most sense to have the Z06 be a high-rpm version of the base model, and the ZR1 be the larger displacement.
I do really hope they refresh the Z06/ZR1 motors, otherwise they are going to seem especially dated compared to a 450 hp + base engine
Those are my prediction!
D/I motors have been having a hard time running without clogging up the intake valves. Audi/VW seen to be really bad with many others like lexus 2.5 having issues as well. Lexus has DUAL injection on their 3.5motor.
I have not seen any major reports about this being a big issue on the GM D/I 6cyl and 4cyl but the V8 is a whole other monster esp since it will be used in performance cars and large trucks. No room for major wide failure there.
My guess would be that the DI 6.2L V8 they were talking about in 2007 is how they worked around the valve issues before they came out with the DI 3.6 V6 a little later in 2008. So, they already knew they wouldn't have those problems with the 3.6, I would bet.
That's fine, but my points still stand. You can't compare the 2.
Why does DI clog intake valves? I would think it would be the opposite, since all that comes through the intake is air.
Or is that the issue? No solvent (gasoline) to dissolve carbon, perhaps? Which I'm assuming would get there from valve overlap?:hmm:
And I also think comparing weight to a twin turbo V8 is kind of silly. Unless you're not including the turbos...then it's just silly for other reasons.
The N55 is probably a better comparison, simply because it's DI and is basically just replacing displacement (apparently there IS a replacement 😉) with forced induction. Those things are way underrated at 300hp and could do 400-500 pretty easily. And weight is a little under 450lbs, I believe.
Again, GM builds damn good engines. You just have to wonder what they could do with newer tech. DI is a good step forward, but the LS/LT motors are still kind of the Nascar of the auto indrustry (yeah, it's impressive what you do with a carbed small block and a four speed...but WHY?)
Traditional fuel injection through the intake manifold ports has a washing effect on intake valves because the air/fuel mixture is passing through it.
Direct injection is squirting fuel directly into the cylinder with only air passing through the intake manifold and intake valves.
The problem is EGR can force carbon rich air into the intake manifold for emission purposes. Since DI doesn't has the same washing affect as traditional FI the carbon can build up.
Ah...didn't think about EGR. Or know that they were using it, for that matter (some makes are now doing okay without it).
