new distributed.net client and project RC5-72 + pproxy info
speed01
1,167
If I install the new client to the same place the old one was and it uses the old .ini file, do I have to rejoin the TeAm or will it continue where we left off....?
ViRGE
Elite Member, Moderator Emeritus
167
As long as you use the same email address, you'll still be on the team. Any other setting doesn't make a difference. I believe Dnet reccomends deleting your current INI though, so you might want to re-create it under the 2.900 client anyhow.
